Ignition
Old Dec 14, 2003 | 10:25 AM
BirdSound's Avatar
Ignition
First, thanks to everyone who has taken time to post information here, great forum.
I am on my 3rd Camaro. I had a 75 Rally Sport 350, a 82 Sport Coupe 305 and now a 95Z 350 LT1 6 Speed.
My car started intermittantly not starting, and now is consistantly not starting. I have checked the key9s0 individually and through the cylinder. The ohms are dead on on both. Several times it appeared the cluth engage switch was holding me out, but it checked okay, though it ittermittantly would not open in the disengaged (clutch out) position. It looks like I need to check the the starter enable relay and verify it is reciving the signal from the decoder module. If it is not, I will have to assume its the module itself. Any thoughts or recomendations on how I should proceed would be appreciated.
Thanks,
Paul
Old Dec 14, 2003 | 10:31 AM
ChevyIron's Avatar
Make sure your grounds on the starter and the ignition module are good and tight.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aaront810
Sep 11, 2015 11:24 AM
