Stocl LT1 castings, 290 cfm.. possible?
Old Dec 15, 2003 | 08:52 PM
5.0THIS's Avatar
Here's some more detail..... apparently on a certain person's heads this was achieved with no welding done to the heads at all, and this flow was achieved between 500 and 550 lift, with higher numbers above that..... any thoughts from some of our resident cylinder head porters and experts.....
Old Dec 15, 2003 | 09:10 PM
jonaddis84's Avatar
Its probably possible, but not worthwhile. At that point you would have so much air trying to flow through there that you would lose good velocity and definitely screw with the swirl required to make real HP. This is where a good porter comes in, sure I could hog the hell out of the ports and possibly achieve more CFM than them, but they would not WORK near as well as a good porters.
Old Dec 15, 2003 | 09:29 PM
kmook's Avatar
Advanced Tech Moderator
LoL it all depends on what flow bench, how its calabrated, etc. It's possible, but in the end futile unless we are racing flow #s...
Old Dec 16, 2003 | 12:46 AM
5.0THIS's Avatar
Any other cylinder head guys have any thoughts?
Old Dec 16, 2003 | 07:59 AM
NightTrain66's Avatar
I guess it is possible......
like others mentioned,
Alot would depend on how accurate the bench is. A "crazy" valve job that flows good at high lift but destroys EVERYTHING down low might get you close.
To get these #'s from a stock LT1 casting, you would probably need to do a lil welding at the pushrod pinch (and maybe on the roof), change the hardened seats in the heads to accept larger valves, etc.. . . .
all in all, it usually doesn't make much sense to spend this kinda $$$ on a stock casting unless you are in a certain class that requires an LT1 casting. An AFR 210/220 could probably be purchased for about the same $$$ that it would cost to get all of this done. If you are doing the work your self and would just be out the time, it might make sense.
If your set up is serious enough to need all of this and if you are gonna pay $1800-$2500 for some LT1 heads, you would probably be better off with the AFR's.
There again, it is not "impossible", it would be very impressive if the stock seats can be retained, no welding needed and the low and mid lift #'s are still good in the head.
NightTrain66@msn.com
Old Dec 16, 2003 | 09:36 AM
Fastbird93's Avatar
Wouldn't you be running into a huge choking point with the runners anyway??? You can only open those up so far to support so much.
*Emilia*
May 13, 2015 09:05 AM
pimpss96
Feb 12, 2015 01:28 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
