Please help me figure this out
Old Dec 13, 2003 | 11:53 PM
joshp14's Avatar
Arrow Please help me figure this out
So I go out to my car the other day, and the thing won't start....It keeps cranking, but no go. I dink with it somemore holding the pedal to the floor....still, nothing. So I take my dad's car to work and he gets it started later that day having to jump it (cuz the battery died from all the cranking) and when he got it started, it stumbled and coughed and finally cleared itself up. He brought it to my work and it started fine when I got off work a few hours later.
Ran fine for about a day or two and today when I went out to start it....same thing! It would crank and crank and crank, but it wasn't even trying to start! I can't figure this out. It has only done this when facing the wind (I dunno if it's a coincidance or not) and I do have ram air. The day that it first did this, I did rinse the car off with some water and also sprayed under the car too.
Now that I'm donw with my disertation, my question is...
Could I have accidently sprayed water on the optispark? and now it does this intermittent starting thing? Or do you think it's related some other way...such as a fuel problem?
All help is greatly appreciated.
Thanks guys.
Old Dec 14, 2003 | 12:00 AM
97WS6SCharged's Avatar
Opti. Mine did the same thing. Car would start and run fine one day, next it just turned the engine till the battery died.
Old Dec 14, 2003 | 01:27 AM
slashz28's Avatar
check the fuel pressure, maybe a dying fuel pump?? similar to a problem i had, thats what it was hth
Old Dec 14, 2003 | 02:36 AM
revtime's Avatar
Could be a bad coil wire as well.
Mine had a bad one after I first bought it, it would start and run a couple times and then nothing, just cranks and cranks.
Coil wire was bad.
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
NewsBot
Sep 14, 2015 02:02 AM
