Rear sway bar will not fit with TA cover. Any ideas?
Old Dec 16, 2003 | 03:14 PM
Ronin's Avatar
I just had a rear diff with a TA cover on it put on my car and the cover sticks out too far to put the rear sway bar back on. There is no way the sway bar will go on. If you have a TA cover or similar one please let me know if you got the sway bar on. TA Industries claim the cover should fit. The sway bar does not appear to be bent either.
Old Dec 16, 2003 | 03:47 PM
97FormulaWS-6's Avatar
I'm running a TA cover and my swarbar fits fine... no problems...
Old Dec 16, 2003 | 03:55 PM
MattK's Avatar
No problems here, either. I run the 1LE 21mm bar, but I don't see how the 21mm matters either, because I'm nearly a centimeter from having any contact.
Dunno what to say... Is it hitting at the bottom rearward edge of the cover?
Old Dec 16, 2003 | 03:58 PM
Temple's Avatar
I also run a TA cover with no problems of it hitting the sway bar. Don't know what to tell ya...it's got to work!!!
Old Dec 16, 2003 | 04:02 PM
quicksilver97ta's Avatar
Mine hit the panhard rod but not the swaybar.
Old Dec 16, 2003 | 04:07 PM
Ronin's Avatar
I just talked with the previous owner of the rear. He said to try putting the sway bar on with the rear jacked up. It is on a lift now and the rear is sagging all the way down. Maybe that is why it wont go on. I will try it with the rear raised up. Thanks for the help to those that replied.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
siguy
Nov 27, 2014 10:07 AM
thenewkid
Nov 27, 2014 09:41 AM
IgorT.455/406
Feb 1, 2005 06:18 AM
