What's making this ticking sound??
Old Dec 14, 2003 | 11:21 AM
Vomit God's Avatar
It's not an out of adjustment valve. (checked them all while running.)
I don't believe it's an exhaust leak. (stock manifolds, never touched)
And I don't think it's an injector. (Can I safely check them while they are running by pulling plugs one at a time?)
I do know it's coming from the driver side. (Or are at least pretty damn sure)
What else can make the ticking sound?
I'm using Mobile1 5W15 (don't give me S about that, just tell me something if it's related) and changing the oil doesnt do anything to reduce the noise. (duh)
A while ago I tried some injector cleaner for the hell of it, and it sounded like it got louder (and has since stayed "louder")
It's not a scary tick, just an annoyance.. kind of like I am torwards this board with these silly questions..
Please help guys.. Any suggestions will be taken serously.
Old Dec 14, 2003 | 11:40 AM
fastbird96's Avatar
Sounds like a bad lifter.
Old Dec 14, 2003 | 11:42 AM
Cmr0z28's Avatar
Get a stethascope or a long screwdriver and find out exactly where the noise is coming from. From what I understand, some ticking is normal on LT1s due to the injectors. This is what was causing my tick.
Old Dec 14, 2003 | 11:50 AM
94_Z28_guy's Avatar
Sorry, but does it ever go away? Like when cold or after car heats up? Does the ticking increase with engine rpm?
Old Dec 14, 2003 | 12:06 PM
mike 96 ws6's Avatar
that will work fine for injectors but if it's an exhaust leak, the steth/screwdriver may not detect it. get a piece of hose {about 5/16" x 3'} and put one end in your ear and use the other end to probe around the manifolds. you'll need to get the end of the hose real close to the leak in order to hear it, but this will narrow it down to the exact location of the leak.
Old Dec 14, 2003 | 12:07 PM
Vomit God's Avatar
The sound is there from cold start to full running temp and everywhere between.
It is in exact synchronation with the engine RPM
It might be me, but I do think it get slightly (only slightly) louder under deceleration. But it might just be me..
Old Dec 14, 2003 | 12:09 PM
Vomit God's Avatar
I'll try the hose trick in a bit.. Thanks
Old Dec 14, 2003 | 12:15 PM
94_Z28_guy's Avatar
I was wondering cuz mine went away after car heated up (things expanded?) Mine was a loose exaust bolt. All on drivers side you can get to and just check the torque on all of them? Either that or the gasket just developed a leak over time.
Good luck.
Old Dec 14, 2003 | 02:19 PM
VegasZ's Avatar
I had a spark plug wire that was loose and made the same ticking sound. I guess it was arcing. Would increase with engine RPM's. Something to check.
Old Dec 14, 2003 | 05:02 PM
Z28ROC's Avatar
Sounds like a loose spark plug.
Old Dec 14, 2003 | 06:07 PM
Myxtreme1's Avatar
Check and see if it is the PCV. I know mine is loud as heck. But I do feel as if I might be having an exhaust issue on the driver side too.
Old Dec 14, 2003 | 07:09 PM
Vomit God's Avatar
Well thanks for the tips guys..
I'll try to get under the car tomorrow if I'm not working..
I will tinker with the plugs and wires if I can.. I'll also try the hose trick to pinpoint the tick source..
Thanks again guys.. You all rock.
Old Dec 15, 2003 | 02:29 AM
S.J.S.'s Avatar
Does it do it at certain RPM's. I just read this post and thought...."hey my car does that." I can hear mine ticking when I reach around 2500 r's. Sounds like a lil exhaust leak. Very very little.
Old Dec 15, 2003 | 11:12 AM
Vomit God's Avatar
It's pretty much audible most rpm's (of course it varies with the RPM), but gets hard to hear above 2000 or so because the exhaust is quite loud.
I can hear it at higher RPM's if I'm going inder a bridge or something..
I'll try to check out the plug wires today..
F'n1996Z28SS
Aug 23, 2023 11:19 PM
importkiller94
Jan 17, 2015 09:03 PM
smokin25th
Jan 1, 2015 09:06 AM
siguy
Nov 27, 2014 10:07 AM
