What plug wires do you use?
Old Dec 16, 2003 | 07:16 AM
max929's Avatar
My Napa 7mm plug wires are only a couple months old but shooting sparks at boot where they connect to the plug. How could that happen?
Old Dec 16, 2003 | 08:42 AM
Fuels94TA's Avatar
Could either be a crack plug, or crack boot on the wire it self. Pull the wire and inspect the boot area for split's. Since you had the wire's for a couple of months they should be under warranty.
Vinny
Old Dec 16, 2003 | 09:02 AM
Type_O_Negative_1320's Avatar
I've been using the Accel Extreme 9000 wires...haven't had any problems with them whatsoever. I'm on my second set (my longtubes ruined a few wires in the first set), but they're holding up nicely since I rerouted them. I'd also recommend sleeving your wires with some Spectra Firebraid or something similar to keep the wires intact if they get a little too close to your headers or manifolds.
Darth_tsunami
V6 Tech
Sep 18, 2015 01:57 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
grgguy
17
Feb 23, 2015 07:57 PM
