Code 134 Issues?
Old Dec 15, 2003 | 10:36 PM
Kryckter's Avatar
Code 134 Issues?
I have just recently put on a comp cam with long tubes and all the good stuff. I am now recieving a 134 code about the bank 1 sensor 1 O2 sensor. I was wondering if there was a problem with my O2 extensions or has my sensor gone bad. I have checked the wiring and everything seems to be fine. I did have a problem of burning those wires earlier in the day and causing major problems but all else is fixed. Now i just have this light coming on pretty often. Just wanting some opinions!
Old Dec 16, 2003 | 12:37 PM
Could be a problem with either the sensor or the wires. Switch the pre-cat sensors left to right and see if the problem follows the sensor (sensor problem) or stays where it was (wiring problem, or sensor not getting hot enough).
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
armedtrigger
Feb 24, 2015 08:30 PM
Gtpguy
Jan 26, 2015 04:50 PM
David Dorris
Jan 17, 2015 08:10 PM
91Bird305
Aug 5, 2002 01:39 PM
