manifold vacuum source?
Old Dec 14, 2003 | 01:36 PM
y5e06's Avatar
I would like to check the vacuum of my engine to help diagnose a poor running condition. I'm looking for a source of manifold vacuum, not ported vacuum. which sources would work? anyone comming off the sides of the intake manifold? the lines going to either EGR solenoid or fuel pressure regulator?
thanks
Old Dec 14, 2003 | 02:11 PM
Trans-Am's Avatar
Right on the side of the manifold there is a vacuum tree that you can tap right into. I believe the hose size is 3/16. Dont unplug the FPR that will set the car's fuel pressure dead rich. good luck~~~~~~rob
Old Dec 14, 2003 | 02:13 PM
97 SLP Company Car's Avatar
Use the one under the fuel psi line, it's for your vent controls and it's manifold vac. If you use the regulator vac line your giving full fuel psi at an idle and that wouldnt be true vac reading at idle.
Old Dec 14, 2003 | 02:20 PM
y5e06's Avatar
ok, I'll use the one below the FPR nipple. easy to get to. Thanks for the replies!
Old Dec 14, 2003 | 04:42 PM
Any port on the intake manifold (excluding TB) is engine (non-ported) vacuum.
magman
Apr 15, 2016 03:08 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
