Rear Defroster only goes on for about 10 sec
Recently Ive noticed that when I press the button for the rear defroster to go on, it only stays on for about 5-10 sec and doesnt even melt snow or even de-fog the rear window. Is there a relay that I should replace, or anyway I can fix this so the defroster will stay on longer?
Originally posted by Mtrhds94Z
IT's not a relay it's a tin looking circuit breaker..
Replace it with a 30 amp FUSE and that should do it..[it's a common problem!]
Originally posted by 96ltz
You might try to replace the relay first. It's by the drivers door in the dash with the fuses. That fixed mine.
my '94 has the habit of turning off the rear defroster after 3-5 minutes.
I just tried it, with the fuse panel off, rear defroster on, the breaker would get real hot. After 5 minutes, the defroster turned off. The power seat lost power too - it runs off the same breaker. After a minute to cool of, both defroster and seat work again.
I just swapped the breaker with the one above it (Window breaker), now it stays on for 10 minutes, as it should.
Darth Xed
13
Jul 22, 2002 12:45 PM
) Should be circuit breaker
