302 questions
Old Dec 14, 2003 | 11:36 AM
turboaddict's Avatar
302 questions
I have a 327 block I want to use a 283 crank and make a 302 but I want to use fuel injection. will the heads from a LT1 or Ls1 fit on my block?
I read about the engine and fell in love.
I want fuel injection for turbocharging reasons.
thanks
marcus
Old Dec 14, 2003 | 11:45 AM
Cmr0z28's Avatar
No.....LT1 heads use reverse flow cooling.
Old Dec 14, 2003 | 11:57 AM
Prorac1's Avatar
But, you can use gen 1 (1955-1985) heads with an lt1 intake. Hmmmmmmm, interesting. Hope this helps, Prorac1
Old Dec 14, 2003 | 12:06 PM
I'll have to look for some of those heads then. I want a rev happy v8 with alittle boost.
aka import killer.
marcus
Old Dec 14, 2003 | 12:11 PM
NewbieWar's Avatar
just outa curiousity does lt4 also use reverse flow ?
Old Dec 14, 2003 | 12:14 PM
fastbird96's Avatar
Yes, LT4 heads are reverse flow cooling also.
The only differences between the LT1 & LT4 heads are: valve size, port size and the LT4's having raised runners
Old Dec 14, 2003 | 01:10 PM
kgkern01's Avatar
Since LT1 blocks are cast 327 on the block, couldnt you still use a 283 crank and make a 302 LT1/LT4?
Old Dec 14, 2003 | 01:30 PM
Red_94Formula's Avatar
lt1's are not cast 327 they are 350. The 327 number on the block has no refrence to being a 327 block.
Old Dec 14, 2003 | 01:45 PM
kgkern01's Avatar
Wink
What I mean is, that you can put a 3" 283 crank in an LT1 block, with the 4" bore and it will give you a 302. Just as if you did the same with a regular SBC 327 block. And the LT1 block is a reverse cooled 327 "stroked" to 350, just as the SBC 350's were with a 3.48" crank.
Old Dec 14, 2003 | 01:59 PM
chad_g69's Avatar
327 and 350 both are 4inch bore (along w/ 302)
only difference is the stroke
chad
Old Dec 14, 2003 | 03:22 PM
mike 96 ws6's Avatar
if i remember right, the 327's came with both small journal and big journal cranks. i don't know if they made a big journal 283 so your 327 block may need to be a small journal block in order to use the small journal 283 crank. correct me if i'm wrong.
Old Dec 14, 2003 | 05:30 PM
GUMP's Avatar
You can make a 302 using the LT1 block and the L99 (265 ci) crank.
Daren
Old Dec 14, 2003 | 10:56 PM
kgkern01's Avatar
chad
Thats what I was trying to say, that the bore on the blocks were the same, just the stroke is different.
As far as the smaller journal cranks, there are a few places that make spacers I believe for using a small journal crank in a big journal block. I have heard the same as Gump said also about using the similar L99 crank from caprices to make a 302.
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Carson96Z28
Aug 28, 2002 05:23 PM
guionM
18
Jul 11, 2002 01:45 AM
