Mobil 1 synthetic
Old Dec 14, 2003 | 08:56 PM
FastWhiteTA's Avatar
Mobil 1 synthetic
Is it good to switch to Synthetic oil after only using regular oil for the life of the engine. My TA just turned 100k yesterday, and I want it to last as long as possible. It still runs great and has awesome power, just wondering if that is something that will help. Right now I use Valvoline Max life. Would it benefit me now to switch to Mobil 1 synthetic? I have heard rumors of both being good and bad, just want to see what the general consensus is.
Old Dec 14, 2003 | 09:46 PM
GreenDemon's Avatar
I use both
2 qts. 10w-30 Mobil 1
3 qts. 10w-30 Valvoline Max Life
Seems to work fairly well. No probs with engine, no probs with mixing diff. types of oil.
Old Dec 14, 2003 | 10:44 PM
Spinner's Avatar
I switched to full syn 1k ago. 137k on the clock. No leaks, runs better then ever
Old Dec 14, 2003 | 10:47 PM
95patriotZ's Avatar
I would switch. Synthetic is a much better oil. The only problem people come across is when they switch, since synthetic doesn't have impurities and deposits like normal oil it will sometimes "reveal" an oil leak. The synthetic doesn't cause it, but since the leak isn't being plugged by deposits anymore it may leak. Do it, I doubt you regret it, and if you do, switch back, easy as that
Old Dec 15, 2003 | 02:14 AM
S.J.S.'s Avatar
Thats true, but recently on this board people haven't had any problems like that. I'd do it. I switched to synthetic when my old motor had like 50k on it. Spun my bearings with 79k. Maybe I shoulda changed it earlier.
Old Dec 15, 2003 | 08:19 AM
95patriotZ's Avatar
even though it doesn't happen to everybody, leaks CAN be revealed. Bottom line : switch, its a way better oil for your car!
Old Dec 15, 2003 | 08:20 AM
JohnD's Avatar
I developed an intake leak big-time when I went to Mobil I at 27K mi. After I fixed that leak, it hasn't leaked a drop since though.
Old Dec 15, 2003 | 08:33 AM
Rx-7 SS's Avatar
definately go for it, just keep an eye open for a while after you do. Im not too sure on mixing and matching dino and synthetic, seems like if it was a good idea more people would be doing it. (or maybe more people are and i havent read about it , definately new to me)
Sep 18, 2015 03:46 PM
92_RS_305
Sep 8, 2015 07:47 PM
browenb
Jul 19, 2015 04:14 PM
mrwz28
Jul 8, 2015 09:11 PM
Aneurysm
Jul 29, 2002 09:23 AM
