Transmission install
Old Dec 14, 2003 | 04:20 PM
fade2blk500's Avatar
1994 black lt1 z28 automatic transmission
My transmission died on my friday finally. i had already bought a god used one that had 60k miles for 400 bucks out of a trans am. I have both the transmisisons sitting next to each other and was matching everything up and making sure its going to work. Everything looks great but the one i bought has a big "K" on the side and the one that came out doesnt, i was just wondering if that means anything ??
thanks
Old Dec 14, 2003 | 04:41 PM
bad79z28's Avatar
The K case is often found in truck applications as well as the "B" bodys. I'm not sure how many of the F-bodys got the same case. Is this a '94 trans? The '95s are different electrically, as are the '96 and '97s.
Kevin
Old Dec 14, 2003 | 07:05 PM
Kevin
Im not sure what year its from i will have to look back in a bunch of old emails to check. but the k case was definitely found in f-bodys? and would the electronics being different keep it from being compatible?
Old Dec 14, 2003 | 11:52 PM
it came out of a 96 trans am, and what exactly is the difference in the K case. i've done research about the PWM already. but didnt find anything definite
Old Dec 15, 2003 | 12:16 AM
bad79z28's Avatar
The K case is typically referred to as the truck case. I've been told that is a better casting than the non-K, but I haven't verified.
A friend tried a '96 transmission in his '94 and it worked fine (or maybe that was a '94 trans in his '96?)
Kevin
Old Dec 15, 2003 | 12:20 AM
Kevin
good deal, everything else matches up so im going to slam it in tonight and see how it does. hopefully all works well i'll give details when i finish.
thanks alot
Craig
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
Collector Car
Jan 5, 2015 10:58 AM
thenewkid
Nov 27, 2014 09:41 AM
