Cam help please
Cam help please
Ok im running the LT4 Hot Cam and i run on nittos threw my cat back exhaust a 12.80 at 107 with a automatic and i was wondering how low would a 230/236 544/555 cam drop my et with a dyno tune.
Are you an M6 or A4? Your time is solid with the Hot Cam. To ask how much better your times would get with the other cam is hard to say. I am sure it would be better but without knowing your other mods it is hard to tell how much better...
I have a Lt1 that i rebuit 355 and put the LT4 conversion kit on it and with that the Lt4 heads are bone stock with 1.6 roller rockers and ive got shorty hooker headers and 52mm throttle body and 3.73gears and catback exhaust with a mail order tune and i run threw my catback exhaust on nittos 12.8 107 and want to no what size cam could i go with to get to low 12s high 11s with a good dyno tune.
Any cam would benefit heavily from a good headjob. If you wanna go bigger and get good results, you will need to open her up a lil. The heads that is. Having a big cam with basically stop heads wont get you near as much as you should.
Originally posted by LT4Z
its a automatic.
its a automatic.
