I'm finally in the 4 fourth gen message board
Old Dec 14, 2003 | 01:45 AM
Irocdriver89's Avatar
Unhappy I'm finally in the 4 fourth gen message board
when i go to start the car it rotates slowly than picks up speed and then will start( all in about 7 sec)it's a 95 t/a I love the fourth gen cars. but I still miss the iroc. I just bought the car yesterday so it's under warrenty please help.
Old Dec 14, 2003 | 03:47 AM
Johnnynsac's Avatar
Might be your battery or a bad connection on the post of the battery. Try cleaning them off.
Old Dec 14, 2003 | 04:07 AM
Zerosheaven's Avatar
its over....the car is going to explode tomorow... sorry
heheeh j/k probly just a loose battery terminal connection, get an optima NOW
Old Dec 14, 2003 | 09:17 AM
slopokrodrigez's Avatar
Put a volt meter on the battery with engine off. It should be at least 12.6 volts. Have someone crank it while you watch the voltmeter. See that it doesn't go below 11 volts while it's cranking. If it does, the battery is probably bad. After the car starts up, see what the voltage is. It should be above 13 volts. If it is, the alternator is good. If it isn't above 13 volts that does not mean the alternator is bad but could also be the battery. Have the battery tested before you replace it.
Be sure to clean all the wires and particularly the engine and chassis ground. Everyone forgets this one.
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
ChrisFrez
Dec 7, 2014 06:01 PM
ChrisFrez
Nov 23, 2014 10:33 AM
