cam break in
Old Dec 14, 2003 | 11:13 PM
twister19's Avatar
cam break in
I just got my cc306 installed, how do you break in this cam.
Old Dec 14, 2003 | 11:32 PM
AsianSensation's Avatar
I broke my hotcam in buy holding the rpm at 2000 for about 10-15 minutes (with a screwdrive to the throttle linkage). Some say there's no need to break in the cam because we have a hydraulic roller set-up. But it doesn't hurt to break it in IMO.
Old Dec 14, 2003 | 11:36 PM
QCKZ28's Avatar
1.run it at 2000rpm for 15-20 minutes, change oil
2.i drove mine easy for 500 miles, no WOT, revs less than 4000rpm, then change oil
3. run it hard
HBHRacing's Avatar
agreed. a good heat cycle can't hurt. get it warm then let it cool off. sounds good to me
Old Dec 14, 2003 | 11:43 PM
Larnach's Avatar
NEWSFLASH!
We have hydraulic roller cams, there is no need to break them in. Just after the install, run the car to see how everything is doing... take it for an easy test drive, come back, drain the oil.
Drive it for another 500 miles, change the oil again and go about your normal maitence cycle.
Old Dec 14, 2003 | 11:46 PM
QCKZ28's Avatar
how would you break in new SR stroker motor?
jesse
Old Dec 15, 2003 | 12:00 AM
nitropatch's Avatar
when i had the ZZ9 cam i just put it in and drove it hard like normal, never had any problems, went 12.9 at 109, i am doin the same with the new cam i got too. but its all on how everyone else does it, some people break them in some dont i dont cuz there is no need too
Old Dec 15, 2003 | 01:45 AM
S.J.S.'s Avatar
jesse
I just broke in my motor. Started her up and ran it for like 10 minutes. Drove it for 20 miles then changed the oil. For the first 500 miles I didn't rev it over 3k and did not exceed 55 mph. Use regular dino oil to break in the motor, not synthetic.
Old Dec 15, 2003 | 01:54 AM
QCKZ28's Avatar
thanks SJS
jad
Old Dec 15, 2003 | 02:00 AM
S.J.S.'s Avatar
No prob..... so you gonna build one??
Old Dec 15, 2003 | 02:21 AM
QCKZ28's Avatar
when my stock motor blows im gonna build a KILLER stroker with big ported AFRs, the car will be paid for soon and im going to start saving $$$$$
Victor Lamb
Aug 26, 2017 02:52 PM
armedtrigger
Feb 24, 2015 08:30 PM
cmyname1
Feb 19, 2015 08:38 PM
grabbem88
Feb 13, 2015 03:09 PM
