vents still not working
Old Dec 16, 2003 | 02:17 AM
Miles-'s Avatar
okay i am getting frusturated, the dash vents have not worked for over a year and I would like to have them back. I have replaced the check valve and tested all of the lines per shoebox's advice. I did find the line from the valve to the vaccuum tank was split so that was replaced but still no air. I dont know where to turn next. Could the vaccuum canister have gone bad? I am at a loss
thanks miles
Old Dec 16, 2003 | 06:36 AM
Pull the HVAC vacuum hose off at the manifold and put a vacuum tester on it. Apply vaccum. If it holds, there are no leaks in the vacuum system. If you still have leaks, trace it down.
*Emilia*
May 13, 2015 09:05 AM
CARiD
Jan 14, 2015 04:00 AM
Catmaigne
Dec 25, 2014 12:16 PM
Red_94Formula
Parts Wanted
Dec 6, 2014 11:07 PM
