What will a dead cylinder look like to the PCM?
Old Dec 14, 2003 | 09:17 AM
F Carline 94's Avatar
Say you have low compression, or a blown head gasket (between cyclinders) for example. Will the unburned air/fuel charge look like a lean condition (high oxygen content) to the O2s? Thus causing the computer to crank up the pulse width on that side. I thought I fixed my exhaust leak, got spark and fuel on all 8, but still got a similar problem. Computer thinks bank 2 is running super lean and has a Pulse width almost double bank one to make up for it.
I know, I know just check the compression already. I'll get there eventually
Sean
Old Dec 14, 2003 | 10:36 AM
Chris 96 WS6's Avatar
A miss ususally looks lean to the PCM, because the 02 sensor sees all that unburned oxygen, it cannot read the fuel at all.
So what generally happens is it adds more fuel trying to correct the "lean" condition. It will be rich out the pipes but read lean.
'96Z28
Jun 30, 2015 05:46 PM
supercharged94Z28
Jun 2, 2015 03:32 PM
Chris Anderson
Jan 27, 2015 08:30 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
derty
Jul 16, 2002 12:20 PM
