What is the best place to send my 30lb. SVO Injectors to get serviced/rebuilt??
Old Dec 16, 2003 | 06:05 PM
Trans-Am's Avatar
I noticed that the injectors are bleeding fuel pressure through them. So i was wondering if anyone knew of a good place to get them serviced for cheap. thanks ~~~~rob
Old Dec 16, 2003 | 08:55 PM
LilJayV10's Avatar
Re: What is the best place to send my 30lb. SVO Injectors to get serviced/rebuilt??
Check in the phone book for desiel shop in your area. Here in town we use Kolb desiel, they check/flow injectors. I would imagine there has to be some place near you too. Hope this helps.
Jason
Old Dec 16, 2003 | 09:04 PM
Trans-Am's Avatar
Sweet, thanks Jason. I'll have to give a call around and see what I can come up with. I have all winter to get it straight one way or another. Damn cars its always something.
Old Dec 20, 2003 | 02:21 AM
Trans-Am's Avatar
TTT anyone else?
Old Dec 20, 2003 | 02:25 AM
LilJayV10's Avatar
did you not find anyone to do it?
Old Dec 21, 2003 | 01:57 PM
Trans-Am's Avatar
I have found a couple of places. Prices ranging from 20-38 per injector, damnit should have bought brand new ones instead of saving a few bucks on used ones. Oh well.
Old Dec 21, 2003 | 07:01 PM
VeryBad's Avatar
I have a shop that will do them for $12 each.
More info on my site.
WitchHunter Performance
Gordon
Old Dec 21, 2003 | 07:50 PM
95BlackTA's Avatar
Gordon
DO you think this would be worth the money for me to do this? I have about 63k miles on my 95. Stock injectors. Would I realize much difference at all you think?
Old Dec 21, 2003 | 08:12 PM
IROCZZ3's Avatar
http://www.cruzinperformance.com/
Old Dec 21, 2003 | 10:56 PM
VeryBad's Avatar
Servicing injectors are not considered a performance increase per say.
What we attempt to do is bring a set back up to new performance and / or identify injectors that have problems. These problems could be the any of the following:
leaking
clogged
corrosion
broken pintle
weak or broken spring
shorted or open coil.
Good injectors should flow within 2% or better of each other ensuring that each cylinder has the same air/fuel mixture.
The low end driveability is usually the most noticed improvement after cleaning.
Gordon
Old Dec 21, 2003 | 11:36 PM
Trans-Am's Avatar
Great thanks for the heads up. I just took the injectors off the car tonight and packaged them. I am sending them over to www.affordable-fuel-injection.com $90 to get 'em serviced and they replace all o-rings and misc parts. So we'll see how bad they were when I get the data sheet back. Thanks a lot for everyones suggestions. ~~~~rob
SC97TA
Sep 15, 2002 01:10 AM
rje
Sep 9, 2002 12:35 PM
Wilson
Jul 21, 2002 05:08 PM
