intake/injector cleaning
Old Dec 16, 2003 | 06:58 PM
BigBobsCamaro's Avatar
Question intake/injector cleaning
Anyone know who does injector and intake cleaning in the Dallas Fort Worth area? I've haerd that having injectors flushed and intake combution chambers cleaned using either Sun or Motor Vac
machines can make a huge difference in high milage engines. Thanks.
Old Dec 16, 2003 | 09:47 PM
Hotwire's Avatar
try grabbing a can of Seafoam engine cleaner from your local NAPA and run that through. you can put it in your intake, gas tank, and oil works great, might save ya some cash too.
you can also get the 3m system that the shops use, you pull the fuel pump fuse, hook this bottle up to the fuel rail and fire the car up, let it run till the bottle goes dry and the car shuts off, disconnect it, put fuse back in, and your done.
good luck.
Old Dec 16, 2003 | 10:36 PM
fozziez28's Avatar
i put 44k in my car. I bought it at the dealer, it was pretty good stuff. they have another treatment at your local dealer, it was real pricey. I have heard good things about the 3m one as well. -Michael
Jeff1904
Jun 5, 2016 05:00 PM
marlar98
Sep 19, 2015 07:53 AM
Daluchman1974
Sep 11, 2015 06:12 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
