Need a few random camaro screw sizes
#1 - The screw size for the REAR side marker/blinker lights. The ones in the sides of the bumper.
#2 - The screw size of the screw in the console, in the frontmost part (under the radio in the CD/tape holder)
#3 - The screw size for the plastic piece in the door panel in the center behind the door handle.
Any help would be great
I'll take these as I can...
#3, the screw that holds the plastic piece behind the interior door pull to the door, is a (M4.2x1.15x20) GM Part number: 10092102
#2 I'm not sure which one you're talking about
#1 The screw that holds the rear side marker lense to the bumper is a (M4.2x1.41x20) GM Part Number: 11504655.
Hope that helps...
Hope that helps...
I know what your talkign about, i dont no the exact # for it. Ive taken mine out many times, its aabout 1 inch long and i believe its a 10 mm size head bolt.....possibly 8 mm, guess it doesnt help that much though.
Bill
Bill
I can't get the actual size, but I did find what I believe you are talking about...
Its a Hex screw with flat washer. Actually for the floor console. GM part number 12337838
Sorry I can't be more help than that.
Re: Need a few random camaro screw sizes
Originally Posted by Spinner
up for reference
Originally Posted by shoebox
I don't get it. What's the point in bumping this up? A search can find it, if needed. :blah: If eveyone bumped up posts for reference, this place would be chaos.
ChrisFrez
12-28-2014 02:25 PM
ChrisFrez
12-21-2014 09:47 PM
ChrisFrez
12-15-2014 03:09 PM
ChrisFrez
12-07-2014 06:01 PM
