$70 for fuel system clean..Worth it?
Old Dec 15, 2003 | 10:19 PM
95BlackTA's Avatar
My trusted mechanic down the street...I was talking to him about checking the fuel system. He said for 70 bucks they will do a 3 stage chemical clean of the fuel system. I use the little 3 dollar bottles like every 3k miles, but this one is ofcourse better. BUT is it worth the 70 bucks?
Car has 63k miles.
Old Dec 15, 2003 | 10:31 PM
scyzoryk's Avatar
NO!!!!
Old Dec 15, 2003 | 10:32 PM
95BlackTA's Avatar
lol, so I guess that means its not worth it huh?
Old Dec 15, 2003 | 10:39 PM
scyzoryk's Avatar
Just go and buy 3 stage chemical cleaning system from auto zone (the same stuff that your mechanic uses), and change fuel filter ($10??)...
Sebastian
ps. You can paypal the rest of the money to sebastianek@23hotmail.com
Old Dec 15, 2003 | 11:09 PM
VeryBad's Avatar
Try not to get too carried away with the chemicals...... Most any chemical that can really loosen deposits is usually harsh enough to damage seals and o-rings. If you must use something, try Chevron's Techron additive, seems to work as good as any in tank cleaner and does minimal damage to the rest of the system.
The Multec injectors used in your car aren't prone to clogging as bad as some of the earlier L98 units.
If you really want to do it right, get the injectors serviced and then you will know what they are doing.
Gordon
WitchHunter Performance
Fuel Injector Cleaning & Flow testing
Old Dec 15, 2003 | 11:13 PM
Unique07's Avatar
Just a little insight here...
I do have some experience with the subject (I bought the kit for FI vehicles), and what your local mechanic is offering is a pressure cleaning. It works well, and is the only way to do it when the car won't reliably well enough to even drive to get it serviced. Read the details and you'll see that the engine 'runs' on this can of cleaner, and dilutes it with no tank gas, making it more efficient. It won't replace $3 in-the-tank cleaners, but they're two different beasts..
He's most likely using a pressurized cleaner, like 3M's:
http://shop.store.yahoo.com/rodi/3mfuinclae40.html
...the accompanying hose kit to screw onto the fuel rail runs $80-100...and the solvent around $15 per can. Similar kits with pump up external solvent tanks run more $$...
With that said, you could almost pay for the 3m kit for the price of a $70 cleaning - On the other hand, if you dropped $100 on a 'tool', you'd make sure you charged enough to pay for the investment quickly...
Just my $0.02
Old Dec 15, 2003 | 11:14 PM
lt1hatesme's Avatar
go to napa and buy a can or two of sea foam.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
Jul 4, 2005 05:00 PM
