NEED BOLT SIZE help ASAP!!!
Old Dec 15, 2003 | 08:58 PM
LT1CST's Avatar
Hey Guys wassup. Well That milkshake color that I had in my heads. Was for sure blown gaskets. I pulled the head off the driver side. COOLANT came out all over the place. Heres what i need help on. ILl make it real quick. THE SIZE is the bolt HOLDING the coolant passages behind the heads. I cant find that damm socket.? If you know please reply. Thanks
Also. Thinking about getting long tubes. What kinda of people out there have good Headers and runing good with them. Thanks
Chris
Old Dec 15, 2003 | 09:05 PM
AsianSensation's Avatar
I used a wrench on the banjo bolt. Wasn't enough room for a socket.
Old Dec 15, 2003 | 09:11 PM
LT1CST's Avatar
Well i was able to slide the head off. So its kinda of just dangling right now By the pipe. SO I can get a socket back there now no problem. What size bolt did you use??
Chris
ttt
Old Dec 15, 2003 | 09:16 PM
It's a special bolt....banjo bolt with crush washers.
http://www.97ta.com/misc_pic/misc70.jpg
Old Dec 15, 2003 | 11:23 PM
Unique07's Avatar
From reading here, people have had the best luck with pulling BOTH heads and leaving that part intact. You'll need a buddy, most likely, to help you lift them both off.
If you have a specific reason for only removing ONE head, then make sure your local dealer has one in stock. There's a good chance you'll need it...
Lots o' luck..
Old Dec 16, 2003 | 12:00 AM
LT1CST's Avatar
Yeah thass exactly what I want to do. IS just leave that assembly were it is. I have no reason to pull it out. I was jus saying since I have the driver side head off ALL READY leaving leaving the head hooked up to that bolt that bolts the coolant piping to it, I was able to get a socket back there. ALL i had to is slide it upward and I can fit a socket. I JUST NEED THE SPECIFIC SOCKET Size. Ive tried every socket that I hace. 5/8's 7/16/ etc... So thass all. Thanks
CHris
ttt
Old Dec 16, 2003 | 06:37 AM
15mm?
Old Dec 16, 2003 | 11:04 AM
LT1CST's Avatar
Thanks shoe. ILL give it a try. NOW I would like to get into my LT discusion. IM sure theres alotof people here running HOOKER long tubes. I hered there really good. MY concern. IS that I have a 1.5 drop in the front. IM worried about the headers hitting the ground on certain terrians. What kinda of set ups do you guys have that are running LT's? Do you have skid plates under neather there or somthing to protect it?
Chris
ttt
Old Dec 16, 2003 | 12:33 PM
94 CAMRO Z28's Avatar
When I had to pull my heads to fix a leak, I just pulled both them out together...It would have made it much easier to have someone there to help but I was able to lift both out together, lay them down on the cardboard, clean up the surfaces, and then put them back on.
Aaron
Old Dec 16, 2003 | 01:49 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
its 15mm. However, if they are orig.. they are the old narrow head design and tend to strip, in which case its vice-grip territory. if you buy new ones, they will look like the picture above, and then they work much better
Old Dec 16, 2003 | 02:29 PM
LT1CST's Avatar
Got them off with the 15mm. Thanks guys. SO what kinda of headers are you guys running? I have BBK shorties. BUt I want to upgrade to LT's. I guess HOOKERs. What are you guys running with. IM worried about clearance issues underneath the car. Thanks
Chris
ttt
HectorM52
Jul 30, 2017 11:46 AM
maybe2fast
Mar 16, 2015 09:45 AM
jj_burchiel
Classic Engine Tech
Mar 13, 2015 11:20 PM
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
