which Header gaskets???
Old Dec 15, 2003 | 03:01 PM
Blackfire's Avatar
I have ASM headers, when i put them on, i used the gaskets that came with the headers. big mistake, i have some exhaust leaks. anyhow, what header gaskets do you all suggest? also, should i use locktite on the bolts when i put them back on?
Old Dec 15, 2003 | 03:03 PM
Bastardcat's Avatar
Re: which Header gaskets???
Fel-Pro 1406
Old Dec 15, 2003 | 03:05 PM
TransAm219's Avatar
I used fel-pro gaskets and havent had one problem with them
I probably wouldnt use locktite , i didnt use it and I was ok
Old Dec 15, 2003 | 03:06 PM
jkipp84's Avatar
No need for lock-tite. You will have to retighten them once maybe twice after a heat cycle or two and you'll be good to go from there.
You can get the 1406's from Autozone, Advance, etc. Don't bother with mail ordering them.
Old Dec 15, 2003 | 03:18 PM
Blackfire's Avatar
all right, thanks alot guys
Old Dec 15, 2003 | 03:28 PM
suprchrged400's Avatar
I got tired of messing around with fiber type gaskets. I use solid copper header gaskets that I got from summit racing for 25 bucks, THey sealed great, header bolts aren't backing off either
Old Dec 15, 2003 | 03:48 PM
ibanez6rg's Avatar
Fel-Pros!
Old Dec 15, 2003 | 09:59 PM
revtime's Avatar
Mr Gasket Copper Seals.
Glad I went ahead and bought these when I bought the headers.
Midnight_Z
Feb 16, 2016 09:36 PM
dylan1303
May 22, 2015 12:24 PM
4586
Apr 29, 2015 01:43 PM
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
rick350
Mar 16, 2015 02:59 PM
