Loss of power....Exhaust leak?
Old Dec 14, 2003 | 05:12 PM
WhiteBeast's Avatar
Ok, i just finished installing my exhaust manifolds, y-pipe and muffler. Right now when i drive it around it seems like it has lost a lot of power. I can hear an exhaust leak coming from the passenger side exhaust manifold where the pipe connects to the y-pipe..This is because i lost the nut that connects the 2 together.
So for right now i just have 2 bolts out of the 3 holding the y-pipe to manifold together....
Would this cause a loss of power that i could actually feel? Also when i do drive it, there is a rumbling shacking feeling.
Old Dec 14, 2003 | 05:47 PM
red 95 z28 lt1's Avatar
yes i had the same problem i snapped 2 of 3 bolts on the passenger side and i had such a bad exhaust leak i noticed a loss in power (why i dont know) also check for clearance between the Y- pipe and the cross member
Old Dec 14, 2003 | 06:01 PM
Myxtreme1's Avatar
Was the leak sound a puffing or how would you describe the sound?
Old Dec 14, 2003 | 06:39 PM
WhiteBeast's Avatar
Ok. I got back under and tightened down all of the bolts again. I also noticed that the muffler pipe that connects to the catalytic converter was rubbing the crossmember. So after readjusting everything I found that there was no longer any vibration or shaking. The exhaust leak that is coming from the passenger side exhaust manifold is more like a "puffing" clicking sound.
I guess all i have to do now is rethread that one bolt.
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
