Lt! Specs
Old Dec 15, 2003 | 05:52 PM
dreamer420's Avatar
Lt! Specs
any one know if it is a good idea to put in 30lb injector to a 94 LT1 or what is the size of the stock ones?
Also my engine is out of a CHP car any one knoe what they do to them ???
Old Dec 15, 2003 | 10:30 PM
RacinLT1's Avatar
shouldnt need 30lb injectors for a stocker.
as far as highway patrol cars go,at most they get additional coolers,oil/ps etc. the other issue is iron heads,all caprices/impala's AFAIK have iron heads,whereas Vette/Fbody has alum.
Old Dec 15, 2003 | 10:59 PM
12Second3rdgen's Avatar
I have talked to the guy that modifies the Oregon State police Camaros when he was vinning my Camaro, and he told me that all they do is put an aluminum driveshaft in them and do some air intake modifications. These were LT1's tho.
Old Dec 16, 2003 | 12:07 AM
dreamer420's Avatar
LT1 in a toyota P.U 4x4
Any goood suggestion for hp mods. I will have the msd 6 & coil, ele wp, ele fan, port & polished heads, upgranded fuel pump,( the in tank by GMS 255lph & regulator, mass air and thats all right now. any help would be great. this motor will be in a toytoa 4x4 W/ 5 speed will the computer need to be recalabrated????
Old Dec 16, 2003 | 03:22 AM
dkeers's Avatar
Talk to Ion at Madz28.com about tuning your computer, he does a great job for a great price. He might be closed until after christmas. If the motor came out of a car with an automatic, you need to make some changes. If you change the cam, you will probably need to make some adjustments to get it to idle right and make the power it should. Ion did all of this for me and I think it cost about $75 with free updates if I make more changes.
Old Dec 16, 2003 | 09:10 AM
Re: Lt! Specs
First, find out what kind of car the engine came out of. Makes a difference as to what the path to more power is. If it was out of a 94-97 F-body or Corvette, the injectors are nominal 24#/HR (24.9 in the PCM tables). You will be OK with the stock injectors up to about 400-425flywheelHP. Beyond that get 30's.
You also might want to rethink where you posted this question.... "N2O Tech" doesn't seem to be the correct place. Perhaps it should be on "LT1 Tech"???
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
cmsmith
Sep 14, 2015 09:09 PM
NewsBot
Sep 14, 2015 09:20 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
