Tall Valve Covers
Old Dec 15, 2003 | 04:58 PM
Heatmaker's Avatar
Advanced Member
Arrow Tall Valve Covers
Anyone using "Tall" valve covers? What did you have to do to make them fit?
Old Dec 15, 2003 | 05:08 PM
ibanez6rg's Avatar
I'm not sure... assuming longer bolts and the alternator being mounted elsewhere.
Old Dec 15, 2003 | 05:11 PM
Heatmaker's Avatar
Advanced Member
That's what I was wondering about the Altenator...If it would be ok to cut and weld the valve cover to fit it.
Old Dec 15, 2003 | 05:40 PM
Mike383LT1's Avatar
TALL VALVE COVERS
i have a set of trans dapt tall cast aluminum that i had notched for the altinator they look a hell of alot better than the black factory deal
Old Dec 15, 2003 | 07:22 PM
kmook's Avatar
Advanced Tech Moderator
Yep move the alt down low or have the covers notched...
Old Dec 15, 2003 | 07:25 PM
ibanez6rg's Avatar
Nice avatar Ken
Old Dec 15, 2003 | 07:54 PM
Heatmaker's Avatar
Advanced Member
How do I notch..... or where can I get the covers notched?
Old Dec 15, 2003 | 08:28 PM
kmook's Avatar
You would need to bring it to a local machine shop or such unless you are comfortable working with alum yourself...
Originally posted by ibanez6rg
Nice avatar Ken
Old Dec 15, 2003 | 08:49 PM
PatriotTA's Avatar
Yeah that's fine if you can TIG aluminum.... I think you can also deform the valve cover slightly to clear the alt. I'm just going to move my alt to a different place, probably near where my air pump used to be and use a custom pulley setup.
Old Dec 15, 2003 | 08:54 PM
jim88iroc305's Avatar
Cool
do a search here for valve covers.
i went with the proform tall polished aluminum center bolts and grinded the rear of the alternator until it fit.
I did it when I saw it could be done in pics posted in a vc thread.
Old Dec 15, 2003 | 09:07 PM
jonaddis84's Avatar
*cough*...... http://www.speedspecialty.com/store/...330820efe8dc1f
Old Dec 16, 2003 | 03:16 AM
dkeers's Avatar
I have seen a few different kinds of valve covers that come notched on ebay and other places. I don't know how tall they are but they should be fine to clear most roller rockers. I had someone who is very good at welding notch my valve covers on a mill and weld them up. They came out great.
Old Dec 16, 2003 | 03:25 AM
Zerosheaven's Avatar
didt some guy shave a peice of the alternaor off?? i would say go for that better than messin with the valve covers.
Old Dec 16, 2003 | 03:56 AM
96 WS6's Avatar
Yea that's waht I plan to do, just shave the piece of alternator off. I made a thread about it, do a search for "dynamat valve covers" in the titled in LT1 tech and you should see my thread. In it, SVT Killer LV shows details pictures on the area to shave off before during and after it's done. He also shows a could pics of the clearance between his aftermarket valve covers and the alternator.
Old Dec 16, 2003 | 06:20 AM
kmook's Avatar
I'd like to get an actual height mesurement of those valve covers because from just looking at the pics they look like aftermarket covers but not really "Tall" covers.
When you said "Tall" I think of something like these-
http://store.summitracing.com/partde...57#largerimage
That are like 5" high in the center, in which case you'd have to grind like 1/4 of the alternator off
