Fuel pressure regulator??
Old Dec 14, 2003 | 06:03 PM
BigTed187's Avatar
I was wondering if anyone could tell me what the syptoms are when the fuel pressure regualtor isnt workin right? also how would i check that??
Old Dec 14, 2003 | 06:07 PM
fastbird96's Avatar
Pull the vacuum hose off the FPR while the engine is running. If fuel comes out then it is bad
Old Dec 14, 2003 | 06:09 PM
GreenDemon's Avatar
Go buy a fuel pressure tester kit from your local auto parts store. Put it on, tape it to the windshield and drive around a little. Pressure should be around 43 stock, but of course changes depending on load. If you see spikes and stuff it's probably bad (or fuel pump or filter). But I'm no expert, maybe someone else has some better expertise on fuel systems. My .02.
CaptainObviousI
29
Apr 29, 2021 10:35 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
charchri4
Apr 14, 2015 06:40 PM
