Coolant Temp Sensor
Old Dec 15, 2003 | 03:56 PM
GreenDemon's Avatar
Coolant Temp Sensor
I already know that it's probably gone bad (fans turned on when cold, wouldn't turn on when hot, or just wouldn't turn on), but I was wondering if this could also be culprit for a hard start condition. If my car sits overnight, its two or three cranks and it starts. If it sits for a few minutes, it starts right up. But if it's somewhere in between, it starts when it wants to start. I don't think its the opti, coil, wires, etc., all ignition components have been replaced recently. Just wondering if anyone had any ideas as to what could cause this and no other problems. It seems to run fine at part and full throttle.
Old Dec 15, 2003 | 04:17 PM
Stoopalini's Avatar
The simple answer to your question is "yes". A faulty waterpump coolant temp sensor can cause hard/no start issues.
As Injuneer stated in a previous thread
The PCM uses a richer mixture, based on coolant temperature, to supply the extra fuel when the engine is cold.
Hope this helps,
Thomas.
95_Z28/SS
May 20, 2015 01:23 PM
warmeck
Apr 27, 2015 04:34 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
91Bird305
Aug 8, 2002 12:36 AM
