New MAF, which should i get?
Old Dec 16, 2003 | 01:58 PM
belcher's Avatar
I was installing a CAI about a month ago in montana on my 97 z28, and had to run to work....well i never did finish it, and i moved to san diego.
i shiped my car down and packed up all the parts....well i thought i did.
I CANT FIND MY MAF SENSOR!!!!!!!!!!!!!!!!!!
my CAI is big enough to run straight through, so the car still runs fine.....but i really dont wanna drive without this part.
Plus my SES light is ALWAYS ON now.
anyways, i have to get it smog checked and it wont pass without it. so i need a new one.
should i :
a. buy a grantenelli (spell check)
b. buy a stock one from a member
or
c. buy a z06 MAF ??????
im not nessicarilly looking for more power, but something that is reliable and will turn off that damn service engine soon light. if an after market MAF will turn off the SES light, AND gain in power for the same price, then sweet....but if not, who knows.
Old Dec 16, 2003 | 02:04 PM
SS MPSTR's Avatar
Put a stocker back on.
Old Dec 16, 2003 | 03:49 PM
97FormulaWS-6's Avatar
1st choice would be a stocker
2nd would be a GM Z06 MAF, (NOT the LS1 SPEED ONE!!!)
But this requires an adapter cable (from Ramchargers), and a re-program of your PCM.
Old Dec 16, 2003 | 03:58 PM
belcher's Avatar
si if i throw the stocker back on it should turn off the SES light?
.....anybody have one they want to sell?
Old Dec 16, 2003 | 04:08 PM
you'll have to clear the code, but it'll keep it from coming back on...
Old Dec 16, 2003 | 05:39 PM
belcher's Avatar
how do you clear the code?
Old Dec 16, 2003 | 05:59 PM
94formulabz's Avatar
Stocker.
Unhook your battery to clear the code. That might not be required though, i dunno on a 97.
-brent
Old Dec 16, 2003 | 06:03 PM
GT40MkI's Avatar
Originally posted by 94formulabz
Stocker.
-brent
easier way
put key in car
pull fuse next to door pcm its a 15
pull fuse in fuse box under hood
turn key on
turn key off
insert fuse in door
insert fuse under hood
turn key on no more code
Old Dec 16, 2003 | 06:10 PM
Heatmaker's Avatar
Advanced Member
I thought the trick was to disconnect the battery for 5-10 minutes then reconnect it.
Old Dec 16, 2003 | 06:37 PM
GT40MkI's Avatar
my way takes about 45 sec
i do alot of lt1 stuff
Old Dec 16, 2003 | 06:40 PM
snksknr94's Avatar
Put a stock MAF back in and don't worry about clearing the code. The new sensor will turn the light off and the code will become a history code. Then after a few drive cycles it will clear itself automatically. Dash light will only come on if you have a current code.
Old Dec 16, 2003 | 07:02 PM
belcher's Avatar
thanks guys,
now all i need is a stock MAF....
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
