View Full Version : LT1 Based Engine Tech
- Harmonic Balancer Question
- serpentine belt removal
- A/C compressor not coming on?
- Cheapest forged 383 Shortblock...Where?
- air conditioning question? no enouf air
- Should I use a High Flow Cat or not??
- Help!
- I Have A Problem
- Brake caliper brackets?
- 30lb injectors
- How long is the camaro?
- X/H-pipe nessesary ??
- strange high idle
- Did 110 MPH spedos come in Zs???
- LT1 in a C1500
- part#
- Anybody knows the closest custom tuner to WI?
- need some help with a few questions
- help loose connector
- I bought a super clean 95 Trans Am tell me what you think!!!!
- Will 6500 RPM limiter be safe on a stock engine?
- help! window fell off track
- Next Mod?
- LT4 heads question should i buy
- The dreaded coolant leak!!!!!!!!!!
- Front tire wear
- Anybody have expierence or know anything about lunati timing chains
- Shoebox: need part #
- headers ?
- PCM programming in California
- 1le Lca's
- Final decision on Main Caps!!!
- Resistor for abs light?
- doing electric waterpump (pt#)
- Resetting PCM Codes
- Which header bolts? 1" or 3/4"?
- Pacesetter LTs VS Jethot LTs...
- Collector gaskets
- what 1/4 mile times do you guys run???
- Which cam for my setup??
- NAPA (Precision) OE Timing Set
- Fuel pump
- Brakes making Clank sound?
- exaust leak= running rich?
- What happens when you disconnect the front O2 sensors?
- someone want to direct my headers decision?
- 13.3 MPG after H/C
- Kinda Feelin Dumb
- header question
- As soon as car hits closed loop it runs like crap.
- Want/need an owners manual for free?
- For those Upgrading Brakes
- what tire size 9.5 rim 275 or 285, come in anybody run 285 all four?
- quick question
- Bent Rim Lip
- car running bad when warmed up
- turn signals (i didnt know where to post this)
- cut out , advice please look
- AFR Rev Kit worth it?
- tailpipes still steaming after shut down??
- Hotcam People Question
- motor mounts
- Design/build my new 355!!!! what would u use
- pro-torque 10.5in. 3200 stall/ any good?
- high speed fan not working (w/ fan switch)
- Fuel pumps question...
- whats the deal on 93 headers
- My 6200 mile oil analysis results with German Castrol 0w30
- Most bolt on power and torque
- GMMG catback or true duals?
- where to find an aftermarket 4L60E temp. sensor and gauge?
- What to Do To Motor
- Cam bearing, take a look
- Engine Needs Refresh Before H/C?
- Lifters ok?
- Is 6500 Rev Limiter Safe?
- heads
- ac compressor what other years will fit a 94 cmro?
- Wierd brake stuff.....
- Wheel hop
- Opinions on a install...... gone wrong???
- How Fast have you gone on DR
- So I tried reinstalling the crankshaft HUB with no luck tonight... questions inside
- Double checking before i fire her up...?
- ordering stuff
- What timing chain, water pump on 96
- shift improvement module for a4
- solid roller 383
- are LT's THAT superior to SLP's?
- help ASAP
- emission hook-ups question on headers
- tach jumping around
- Considering going no cats
- Safe highest RPM for stock bottom with hot cam???
- most RWHP for non ported heads
- Who's in the low 12's and gets 15/20+MPG?
- best mods for a 93z
- Data master.. Which sides which? DTC error..
- Tired of Brake Problem, Ditching ABS, Help w/ Wilwood Prop. Valve...
- Question about 1.6 RR's install
- turning radius
- quick bbk throttle body ?
- finding the resestance
- What size BFG DRs for stock 16" wheels?
- install starts tommarrow night--MACS
- Did i damage my engine?
- free service manuals
- Anybody want to predict numbers for my setup?
- part # for LT4 valve springs
- what's the highest cam only dyno?
- Lt1 edit
- Taylor "direct fit" or OTVC?
- where will i see more gains?
- car runs terrible need help
- EGR Question
- LT headers smacking my car
- Just for fun, 10sec with 355
- Passenger side power mirror, in and out?
- 93 LT1 heads, are they different?
- New best Time!
- How to ship 16" Rims w/tires mounted
- anyone w/ aerospace brakes here!! really need help!
- Best place to buy a MAF?
- Went to adjust the valve lashing and this happens!
- Help with Header choice for 396
- Need help installing valve covers?
- Replacing Rotors...any Gotchas??
- Size of front seat belt bolts?
- Help Question About Wheels For Lt1
- Hot And Low
- what hp do i have????????? roughly
- Need advice with new mods
- Is the too much $$$ for a Cam + Header install?
- Can anybody help me with wiring to a convertible switch
- Need sound of Lt1 w/long tubes, no cats and cutout!
- Best speed for best MPG in 6spd?
- wheel/tire question?
- Reusing Bolts...
- Easiest Way To Drain Fuel Tank?
- Dis-assembling alternator case
- timing sets
- svo fuel injectors
- What kind of gains??
- Fuel pump upgrade ?
- Double-Roller and timing cover
- Long Tubes and Eibach springs
- What RWHP are you making with GM 847 and ported heads?
- electric water pump?
- Valve spring & rocker suggestions?
- Jet hot long tube install??
- Head and cam installation
- clutch fried
- Centerforce Dual Friction
- bolts and gaskets..MACs
- Fustrated with unknown noise
- IAT & CAGS bypass (resistor questions)
- will a TQ Converter from a LS1 work on a LT1?
- O2 Sensor Question
- Simple Cam Question
- Coil Question
- Fuel line question
- need some quick help please
- Just a cam install - what's involved?
- Traction control rear.
- Backfire
- P0133 code came on cleared it and it sayed off
- GMMG RW horsepower gains?
- 4rth is stuck , please help.
- Impala SS Shop manual
- Probe Pistons and Rings
- GM 847 Cam Install Complete!!!
- Stock 94 Z28 A4 tranny question
- Easiest headers to install on LT1
- 12 mpg city!?
- What is OBDII code p0100 on a ford?
- What should I set my AFPR at with my mods?
- Cylinder head removal..
- Anyone pull motor from top with A4 attached?
- Going to look at a 97 LT1 tonite, anything specific?
- Question About Putting Weld Wheels On My Late Model Camaro
- pro 5.0 shifter.. nice! but ouch!
- bad to drive on a dying fuel pump?
- Front fascia sitting slightly lower than hood
- Hiding the wires???
- 97 lt1 heads w/ 7/16 stock?
- sealants
- Dangit I used sealant instead of threadlock
- what kind of heads can fit on my 94 formula
- questions: oil capacity & hotspotted flywheel
- E Brake
- what kind of gas?
- my 94 firebird makes almost a grinding noise off start off
- lt1 options
- ignition coil
- Highest Miles on an LT1?
- quick question
- oil pan
- 28lb'ers work for my combo?
- About to start my 355 build up soon.. suggestions?
- E brake tension
- Shoebox here please
- PCM for less.
- How optimistic can i be about 300 rwhp??
- best gaskets and header bolts for MACS
- Car is very hard to start
- Wicked hissing sound under the hood
- LT4 Hot Cam question
- Nitto NT555s?
- Driver power seat going crazy
- Where can I buy an SS spoiler LED brake light?!?!
- suspension
- Zo6 Maf
- FLP LT header owners
- power programmer
- 2 3/4" true duals
- head light out, lf, highs work?
- Car Keep Dying on me!! PLEASE HELP GUYS!!!
- Ultimate Exhaust!
- What combo of mods to out run LS1
- exhaust leak
- boot retainer
- Call out to Joe O
- LT1 Car -- Bolt On Mid 12's?
- torque arm question..
- A couple of notes from my MAC header install (long)
- Flooded?
- Removing high voltage part of opti-
- fuel fittings at the fuel rail
- Opti
- Bigger cam+catalytic converter=more smoke from exhaust until warmed up?
- EX Components 5/16" Guideplates
- Torquing down the windage tray studs
- Installed Granatelli, now it slugs
- o2's on long tubes
- Sluggish
- Fans/actr fuse 6
- Cheapest PLace to get Bilsteins?
- Need Advice On Pullies
- Combustion Chamber Volume
- Need help!
- just put the opti on have questions
- long tube gains?
- What's involved w/ rebuilding calipers?
- Which weld wheels should I get?
- Anyone try the Goodyear Eagle F1 GS-D3 315-35-17 tires?
- brakes
- fuel pressure cupplin?
- Fuel pressure regulator?
- Couple of A/C repair questions
- lowering springs?
