o2's on long tubes
Old Mar 15, 2004 | 06:32 PM
acslinger2525's Avatar
o2's on long tubes
If i get the o2 bugs with my long tubes, does that mean i will be able to just put my factory ones in and they will work with out extensions? Thanks
Old Mar 15, 2004 | 06:33 PM
MEAN LT1's Avatar
Re: o2's on long tubes
Your o2 bungs are just there to get rid of the reaer most o2's. Your still going to need extensions.
Old Mar 15, 2004 | 06:36 PM
so where would i put my front o2s at if i get the long tubes? I have already changed to OBD1 and had the back 2 turned off. If you can, explain to me what i need to order to make my car work.
thanks for the fast reply
Old Mar 15, 2004 | 06:41 PM
matt diamond's Avatar
the front o2s go into the collectors when you have the bungs welded in. the back o2s will have to be deleted using lt1 edit or you will have to run o2 sims. I can get the extensions and o2 sims for you if you want to. I can also get whatever other parts that you need.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MDZ28
Exhaust System
Jun 2, 2015 09:48 PM
drptop70ss
May 4, 2015 08:22 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
