Which weld wheels should I get?
Old Mar 15, 2004 | 05:10 PM
5H9D0W's Avatar
Some guy is selling his Draglite Xp's 15x9 5x4.75 5.5" BS.Is this the best or one of the best wheels to get for my car.If I were to pick one it would have to be the lightest.Any info would be great.There 260 new,what do you think I should offer. Mike
Old Mar 15, 2004 | 05:19 PM
justens95z's Avatar
Just for the two rears? I would think they are worth $400-450. I think most people around here just use the regular Draglites, and they are cheaper.
Old Mar 15, 2004 | 05:30 PM
5H9D0W's Avatar
Will theses wheels fit and if so would they fit on a 12 bolt.
Old Mar 16, 2004 | 12:40 AM
A 15x9 with a 5.5" backspace is going to stick out of the fenders a little. You need a 5.5" BS for a 15x8, 6.5" BS for a 15x9 and a 7.5" BS for a 15x10.
The "XP's" are heavier than the Draglites or Pro-Stars. XP's are "street" wheels, the others are "drag" wheels. No skinnies available in the XP's.
A 12-bolt would typically be supplied in exactly the same width and the same stud bolt circle as the stock rear. No reason the wheels wouldn't swap over.
If you want the lightest available wheels, with the least install hassles.... no longer studs, no spacers, no grinding the rear brake fins... get the Bogart P1's, specifically made for the 4th Gen F-Body.
Old Mar 16, 2004 | 01:17 AM
T/A#4's Avatar
And ............................................ who sells the Bogart wheels ? Never heard of them ?
Old Mar 16, 2004 | 06:44 AM
http://www.bogartwheels.com/
Sales
Old Mar 16, 2004 | 07:24 AM
IDOXLR8's Avatar
Another vote for Bogarts. IMO the nicest drag wheel available for F-bodies.
Old Mar 16, 2004 | 09:23 AM
brandboZ28's Avatar
Bogart D-10's!
As for welds, I would go with a ProStar. They look awesome on the f-body and are a good bit cheaper than the Bogarts
HarleyZ28
Oct 5, 2015 06:23 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
redleader
Wheels and Tires
Jan 22, 2015 04:20 PM
squarehead
Nov 21, 2014 08:02 PM
