Jet hot long tube install??
Old Mar 16, 2004 | 01:07 PM
mavricki18's Avatar
sorry of its a repeat but i dident see any thing when i searched.
Jet Hot LTs on my buddys(auto) 95 TA
do we need ot drop the trans or Kmember?
and dose anyone know of a good step by step install page ?
Old Mar 16, 2004 | 01:10 PM
ibanez6rg's Avatar
I didn't need to drop my k-member. Basically all I took out to install these were starter, alternator, oil filler tube, and spark plugs.
Old Mar 16, 2004 | 01:13 PM
mavricki18's Avatar
oh yea i forgot to say we are using the lift at school. How much more easy is the install with a lift?
Old Mar 16, 2004 | 01:23 PM
Mystic97Z's Avatar
u really should use a lift, unless u can get the car very very high on jacks.
check this out
http://www.theheadfl.com/jethotlt.htm
Old Mar 16, 2004 | 01:25 PM
Valkyn71's Avatar
I did my install with only basic jack stands, not even all the way up.
I removed the motor mounts, spark plugs, and starter, jacked the engine all the way up. Passenger side went in no prob after a little work, had to grind down the lip on the K-member for the drivers side.
All in all took me about 2 hours, granted i had the intake, valve covers, and everything off the front of the engine for a cam install from the beginning.
Old Mar 16, 2004 | 01:44 PM
blazzinbird's Avatar
i just put mine in saterday, all i removed was the alternator, starter, oil dip stick tube, oil filter, and i jacked the car up real high, oh also the stearing linkage
the driver side went on fine, the passanger side was a little harder
Old Mar 16, 2004 | 01:46 PM
ProchargedZ's Avatar
oil filter, spark plugs (not necessary, but might as well), starter, altenator, oil dip stick........ and the kicker..... the motor mounts made all the difference in the world for me.
take out the bolts in the motor mounts, place a piece of wood on a jack and place on oil pan, Jack slowly and carefully until headers go right in.
Just did my Hooker Long tube this weekend...well most of it. Hope to finish tomorrow. Good luck.
Old Mar 16, 2004 | 03:45 PM
Jeffs94Z28's Avatar
your SOOO lucky to have a lift. i wish i had a lift during the install. good luck
LT14LIFE
Feb 9, 2015 09:35 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
RedLineRev
Jan 23, 2003 03:51 PM
