Easiest headers to install on LT1
Old Mar 16, 2004 | 09:37 AM
FyreLance's Avatar
I've heard it's a bear to install headers on an LT1. So what's the easiest ones to install? Is it possible for someone (myself) to install a decent set of headers having never done it before, let alone on an LT1?
Old Mar 16, 2004 | 09:40 AM
chesee48's Avatar
All shorties require the same basic work...plug access on the other hand is a different story...
Lt's involve more work since you are removing the cat...
Old Mar 16, 2004 | 09:45 AM
FyreLance's Avatar
Is it easy to pass sniffer with LT's? I never get visual inspections.
How much harder are LT's to install than shorties?
Old Mar 16, 2004 | 09:47 AM
ibanez6rg's Avatar
Sounds like the Pacesetter LT's are pretty easy.
Old Mar 16, 2004 | 09:55 AM
chesee48's Avatar
pass the sniffer with LT's? Wont work. Unless you get LT's l(ike FLP's ) that still uses the stock cat. Most LT's require you to remove the cat...without the cat = fail
Old Mar 16, 2004 | 10:23 AM
Dan Oldham's Avatar
I've got a cat with my Hooker LTs.
Old Mar 16, 2004 | 10:30 AM
FyreLance's Avatar
Was there something special or custom you had to do to get the cat on or is it supposed to fit a cat?
Old Mar 16, 2004 | 10:31 AM
95_LT1_6SPD's Avatar
If you dont get a visual inspection, you should be able to pass with longutbes with emission fittings and a cat....atleast i hope so
Old Mar 16, 2004 | 10:33 AM
FyreLance's Avatar
I'm not terribly worried about passing emissions. I passed in my 91 with no cat and running rich. If I don't pass I'll go spend 300 bucks on stuff to make it pass emissions and then get an exemption and then take the items back. :P
Old Mar 16, 2004 | 10:38 AM
stereomandan's Avatar
http://www.camaross.com/forums/showt...hreadid=237509
I'm in the middle of my '94-'95 style MAC midlength header install. It is going great. See the link above.
I only had to remove 3 spark plugs. No need to remove the oil filter or jack up the motor.
They are designed to be used with a CAT, so emissions are no problem.
It's a lot of work. I have access to a lift, so that helps A LOT.
You can do it yourself, but just be prepared for a good amount to work no matter what headers you get. LT's are definately more work though than my MAC mids.
Dan
Old Mar 16, 2004 | 11:17 AM
FyreLance's Avatar
What are the supposed gain differences between these mids and full LTs? Do you have any pictures of the mids?
Old Mar 16, 2004 | 11:24 AM
http://www.camaross.com/forums/showt...&highlight=MAC
Here's a link with pictures of mine.
They just aren't as long as LT's. Mid's and shorties have no ground clearance issues. They normally come with the Y-pipe, so you don't need to buy or make one seperately.
There are debates over the gains of each. There have been recent threads about it. You could search about it.
MAC mids have shown 25-30 rwhp gains.
Dan
Old Mar 16, 2004 | 11:30 AM
FyreLance's Avatar
544 for the entire setup including Y-pipe?! Sounds like a great deal to me! I might just have to do that....
Old Mar 16, 2004 | 01:05 PM
chesee48's Avatar
Thats custom tho right? and hes looking to install it himself
Old Mar 17, 2004 | 09:19 AM
FyreLance's Avatar
bump
artic94
Jan 17, 2015 11:19 AM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
