LT4 heads question should i buy
Old Mar 17, 2004 | 04:58 PM
NEOS97SS's Avatar
this is the quick and dirty about them, should i get them
LT4 Heads: very high port velocity, raised port , Ferrera stainless steel valves (2.10/1.625"), Comp Cams 938 springs (coated) with Ti retainers, 10 degree locks, heads are ported to 212cc intake volume, intake bolt hole passages are sleeved, 65cc chambers, chambers are coated as well (for reduction in detonation for power adder or very high compression).
Flow numbers:
Intake
.100 69
.200 128
.300 191
.400 240
.500 282
.600 304
.700 307
.750 310
.800 314
Exhaust
.100 52
.200 110
.300 152
.400 180
.500 201
.600 215
.700 223
.750 227
.800 228
Heads were flowed on a SF600 with a 4.030" bore, 28"
Lifters: Comp Cams EndureX
Pushrods: Comp Magnum 7.900"
Rockers: Crower shaftmount
Old Mar 17, 2004 | 06:52 PM
Josh-'04 GTO's Avatar
You're gonna put those on a stock shortblock???
Old Mar 17, 2004 | 06:56 PM
jdizzell's Avatar
Is it just me, or do those intake flow numbers seem to just want to keep going!!! Hope you have a big cam to reach that kind of lift!!!
Old Mar 17, 2004 | 07:11 PM
That's not all he needs!
Old Mar 18, 2004 | 08:28 PM
arnie's Avatar
Re: LT4 heads question should i buy
Originally posted by NEOS97SS
this is the quick and dirty about them, should i get them....... intake bolt hole passages are sleeved...
I'm drawing a blank. Please explain.
LeftoverChinese
Jan 14, 2024 03:03 PM
MadMav
Feb 6, 2015 11:02 PM
95chwagon
Jan 13, 2015 09:19 PM
Jazsun
Dec 29, 2014 12:14 PM
