Collector gaskets
Old Mar 17, 2004 | 02:54 PM
CamaroBoy96Z28's Avatar
Collector gaskets
I had to take my y-pipe off a while ago and my collector gaskets are mangled. I used the ones that came with my Jet-Hots. Which ones are better to use and wont fall apart when I take the y-pipe off? Or will the collector seal ok and not rust horribly without a gasket?
Old Mar 17, 2004 | 02:59 PM
93transam1234's Avatar
Mine started to leak a few weeks ago, i just got some more at autozone 3" ones. and put ALOT of RTV on them and around them because the y-pipe didnt match up eacactly.
i dont know if there are any you can reuse i would just get new ones every time because they are cheap
Old Mar 17, 2004 | 03:15 PM
Get some "dead soft aluminum" collector gaskets. Will last a lot longer and seal a lot better.
Old Mar 17, 2004 | 03:16 PM
I was thinking aluminum would be better but wasnt sure. I'll definitely give that a try. Thanks.
Old Mar 17, 2004 | 03:27 PM
LWillmann's Avatar
I've seen the Percy's at Autozone before.
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
pepon214tx
Sep 20, 2015 04:48 PM
