Should I use a High Flow Cat or not??
Old Mar 17, 2004 | 07:43 PM
wannabeZo6's Avatar
car currently has true duals...have a hooker catback and y-pipe in the garage, gunna get it put on this weekend, also have a high flow cat......i want to quite it up a bit (just did heads/cam and it has long tubes), should i not use the cat, or maybe use the cat and put a cutout b4 it.......thoughts?.....
Old Mar 17, 2004 | 07:57 PM
kevinCHOPTICON's Avatar
If you want to quiet it up, definatley use a cat. It won't be as much power but will be a lot quieter. I suggest getting a high flow cat from Random Tech, so it is still legal and quiets it some, but won't loose as much power. If you want more power get an electric cut out and weld it before the cat
TitoPR221
May 26, 2015 12:20 AM
alex5366
Mar 8, 2015 11:32 AM
jeff94z28
Sep 11, 2002 02:01 PM
blue89iroc
Jul 26, 2002 04:56 PM
blue89iroc
Jul 18, 2002 03:35 PM
