Resetting PCM Codes
Resetting PCM Codes
I'm having some work on my transmission done and the guy doing it says that some codes are coming up on the PCM. What types of codes would come up on the PCM due to a transmission? It's got a 2400rpm stall, shift kit, beefed up clutches, and springs. The TC is a lock-up.
Also, he's trying to reset the codes, and for some reason the error codes are still present after the PCM has been re-flashed. He's got someone looking into it now.
Any ideas of what can cause this?
A4 related codes on OBD-I:
58 - Transmission fluid temp circuit, voltage low, high temperature
59 - Transmission fluid temp circuit, voltage high, low temperature
72 - VSS loss
73 - Pressure control solenoid circuit, current error
74 - TCS circuit low
75 - Transmission system voltage low
79 - Transmission fluid overtemp
80 - Transmission component slipping
81 - Transmission 2-3 shift solenoid circuit
82 - Transmission 1-2 shift solenoid circuit
84 - (A4) Transmission 3-2 control solenoid circuit
85 - Transmission TCC stuck "on"
90 -Transmission TCC solenoid circuit
72 - VSS loss
armedtrigger
Feb 24, 2015 08:30 PM
