questions: oil capacity & hotspotted flywheel
Old Mar 15, 2004 | 10:40 PM
pvkn1ght's Avatar
couple questions:
1. What is the exact oil fill capacity (w/ filter change) for a 95 LT1? I put around 5.25 every oil change.
2. I have clutch chatter that tranny shops say is due to a hotspotted/warped flywheel and clutch. Is it harmful to drive the car like this? How about at wot?
Thanks, Brian
Old Mar 15, 2004 | 11:23 PM
Camaro97USAF's Avatar
I put around 5.5 quarts, I have a little bigger filter than stock though, should be like 5 or so. As for the chatter, is this a stock clutch, if so and it has alot of miles on it, that might not be too good, but if it's new, some chatter a bit....
Old Mar 15, 2004 | 11:27 PM
Red96Lt1's Avatar
I think the worst you'll do is wear the stock clutch faster. I don't think it will harm anything else, except your nerves.
Old Mar 16, 2004 | 01:33 AM
pvkn1ght's Avatar
oil sounds right on, thanks.
about the clutch chatter, it is a stock clutch with 60k mi on it. i bought the car at 55k and learned how to drive stickshift on it; it was fine until an uphill traffic jam which burned it up pretty good
so now it chatters/shudders, could this damage the driveline or engine at wot due to more vibrations?
uh oh if so, but if not, i have some time to save $ for a new clutch *sigh*
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
SpeedJunkee
Jun 6, 2015 04:27 PM
BigWil
Mar 29, 2015 12:24 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
