Did 110 MPH spedos come in Zs???
Old Mar 17, 2004 | 06:58 PM
CLEAR's Avatar
ok i just traded for a 95z28 6 speed. it has a 110 speedo, is that correct? i thought they only came with a 150. by the way its a ragtop.
Old Mar 17, 2004 | 06:59 PM
Steve0's Avatar
Z28s come stock with 235 width tires as opposed to the 245/50-16s. The wider tires were an option.
Cars with the skinnier tires had the lower mph speedo and a I also believe speed limiter.
Old Mar 17, 2004 | 07:13 PM
Josh-'04 GTO's Avatar
I think it was actually the speed rating of the tires as opposed to the size (I think). If I'm not mistaken, the all season radials got you the 110 speedo, while the ZR radials got you the 150+.
Old Mar 17, 2004 | 07:15 PM
Derrick Redd's Avatar
Yes I have one. If you have stock programming you won't be able to go over 115.
Old Mar 17, 2004 | 07:26 PM
Steve0's Avatar
Hmmm, I've also heard that before and it may very well be true. I think that there were both Z rated and all season 245's. Seeing very few 110mph speedo cars in my life just leads me to believe it had to do with the tire size option.
Old Mar 17, 2004 | 07:41 PM
Brent94Z's Avatar
Super Moderator
I had not heard of that before. In fact, I thought they all came with the same sized tires but the ones that were not ordered with Z rated tires came with the 110 speedo.
FWIW, my 94Z convertible has a 110 speedo. Bummer
Old Mar 17, 2004 | 07:42 PM
maddog89's Avatar
it had nothing to do with the size of the tire it was the rating,,,,,,,,,,,,,,,,,if you opted for the z rated tires you got the 160 speedo............................................ ........................
Old Mar 17, 2004 | 07:45 PM
unvc92camarors's Avatar
maddog's right but...i thought it tied in with the rear axle (2.73's gotthe 110 and 3.23's got the 150 or 155, however you like to look at it)
and i know all m6's had a performance gear 3.42 (save forthe m29 viper t56 in 93 which had 3.23's) which i thought all had 150mph speedos because of it
Old Mar 17, 2004 | 07:46 PM
Steve0's Avatar
It looks like we were both right.
http://www.f-body.org/faq/4/4_5.htm#ch4_5g
All Z28s, Formulas, and Trans Ams come with Good Year Eagle GA (235/55R16) touring tires as stock. Options for Good Year Eagle GS-C (245/50ZR16) tires (option QLC) or Good Year Eagle RS-A (245/50ZR16) tires (option QFZ) are also available. With either of these Z-rated tires, the car gets a the 155 MPH speedometer and does NOT have a speed limiter.
Turns out both of the bigger tires were Z rated.
edit - also look here.
Old Mar 17, 2004 | 08:25 PM
flyinZ's Avatar
ya, I have the 110...my speed limiter, when I bought the car, was only 108...which sucked...heh
Old Mar 17, 2004 | 08:31 PM
Amped96's Avatar
My car is wierd. I bought it used, but it came with the 150 speedo, but it had the governor at 115. I checked on the door and it came with the 235 T-rated tires. The previous owner definately did not seem like the type that would swap out the speedos for the better one though.
Old Mar 17, 2004 | 08:44 PM
mPoRtSsUcK's Avatar
all Zs come with 150... but some are governed to 118 due to v6 (t rated) tires
formulas came with the 120 speedo... ur car possibly was a v6 with a swap... check the vin
Old Mar 17, 2004 | 08:47 PM
NewbieWar's Avatar
this is not true, ive got 2.73 rear and ive got the 155 speedo
and same w/ my buddy hes got the 2.73 and 155 speedo
why would the higher top end car get the slower speed?
it may be the other way around
Old Mar 17, 2004 | 08:57 PM
NoSlowCamaro's Avatar
Is there any way to see if your car came with Z rated tires from the factory?? My car has the 155 speedometer..but has the 2.73's..i've had it to 115 a couple of times, but ive always backed off around there...i've never held it to 118 i guess to feel if it had a governor..now my dad claims that he has seen an indicated 126 before, and claims it was still pullin good. But i have 235's on there, even though those are the tires that the dealership put on there when we bought it with 16K miles on it. There Z-rated, but i dont know what it came with from the factory..so my dad claims he has seen 126..is there any code on the door that i can tell for sure what it came with from the factory..and if i really have the governor or not..i really dont wanna run out and "test" it..
Old Mar 17, 2004 | 08:59 PM
NewbieWar's Avatar
donno where u live but just push it on the freeway doesnt take that long to get there trust me, if ur goin 60 mph u should be upto atleast 130+ in another 10 seconds
i tested mine out a few days after i got it at 135 and it was still pullin good
