just put the opti on have questions
Old Mar 15, 2004 | 06:05 PM
blazzinbird's Avatar
ok i just putt he opti on, and i made am ark with a mrker so i know it was lined up, well when i slide it on there is like maybe a tiny space between the brackets and the block is this normal, i took it off several times and every time it is like this, i dont want to ruin this opti please help
Old Mar 15, 2004 | 06:10 PM
anyone with a anwser
Old Mar 15, 2004 | 06:15 PM
RCF925's Avatar
What year car? There should be no gap between the Opti and where the bolts go in. Don't pull it on with the bolts either because you can ruin it that way. If you have a vented Opti then maybe the dowel is to long
Old Mar 15, 2004 | 06:19 PM
i have a 96, and why would the dowl pin be longer, this was just a opti change everything else is stock
Old Mar 15, 2004 | 06:21 PM
HBHRacing's Avatar
are you sure the pin is lined up? just cause the orientaion of the opti is the same doesn;t mean the slot for the pin is..
Old Mar 15, 2004 | 06:22 PM
also if i tuen it just alittle it wont go on, but if i turn it back you can here it pop into place
Old Mar 15, 2004 | 06:25 PM
i can see where the pin is, and i have the back of the opti lines up, and i put a black mark on top of the opti so i could tell if it spun some, it is top center maybe i need to push it alittle harder
Old Mar 15, 2004 | 06:41 PM
anyone else
Old Mar 15, 2004 | 08:38 PM
can anyone give a few pointers
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 27, 2014 10:06 AM
Injuneer
Dec 15, 2014 09:36 AM
AlaskaZ28
Dec 10, 2014 02:37 PM
pologreen97z
Dec 2, 2014 10:42 AM
