What size BFG DRs for stock 16" wheels?
Old Mar 16, 2004 | 08:03 PM
PatriotTA's Avatar
What is the correct tire size for the BFG drag radials using the stock 16x8 wheels on my 1995 Trans Am? Also, is there a big difference between the Comp T/A and the G-Force TA? The G-Force looks like it would hook better, but has anyone had experience with both?
Old Mar 16, 2004 | 08:07 PM
JKDZ28's Avatar
255/50/16
get the comp t/a
1msfyter's Avatar
255/50/16 I have those and they are huge compared to my stock 255's .Also go to Costco if you have one near you. $113 each
Old Mar 16, 2004 | 08:39 PM
PatriotTA's Avatar
Originally posted by JKDZ28
255/50/16
get the comp t/a
Just curious why you say the comp t/a.
Old Mar 16, 2004 | 09:17 PM
RamAir95TA's Avatar
I think the BFG Drags actually say "BFG Comp T/A Drag Radial" on them if I remember mine correctly, but that shouldn't really have anything to do with it.
Old Mar 16, 2004 | 09:20 PM
PatriotTA's Avatar
Well I guess there's actually 2 styles of BFG drag radials - the Comp TA and G-Force TA. I was wondering which one offered better traction.
Old Mar 16, 2004 | 09:42 PM
justens95z's Avatar
I think the Comp T/A would probably be better. The G-Force has a stiffer side wall, usually used for tires with lower aspect ratios. I would go with the Comp T/A. There are some guys going VERY fast with that tire.
Old Mar 16, 2004 | 10:37 PM
ThirdGenLT1's Avatar
I say the G-Force T/A KDW. If you go to www.tirerack.com and compare it with the comp T/A I think you might agree. Dry traction is nearly the same on both, but wet traction and hydro-resistance are SUPERIOR on the G-Force T/A KDW. I thing the G-Force is about $10 more per tire, but I feel it's 10 bucks well spent! If you care about apperance, I think the G-Force T/A KDW looks better too!
Links to each tire...
G-Force T/A KDW:
http://www.tirerack.com/tires/tires....orce+T%2FA+KDW
Comp T/A Drag radial:
http://www.tirerack.com/tires/tires....FA+Drag+Radial
Just my opinoin, Matt
Old Mar 16, 2004 | 11:31 PM
simple's Avatar
the KDW isnt a drag radial tho, its an 'all' season radial, excellent tire tho all around, i like mine!
and i think BFG only makes one size drag radial for a 16" wheel 255-50-16!? if i'm not mistaken
Old Mar 16, 2004 | 11:46 PM
LilJayV10's Avatar
My friend had some KDW's on his 94 T/A. those things are freakin worthless on the track. I know thats not what they are designed for. I am just throwing that out there in case someone would consider them over a drag radial.
Jason
Old Mar 17, 2004 | 12:01 AM
CamaroBoy96Z28's Avatar
I have 255/50/16 Comp T/A DRs and like them. My friend has the G-Force Drag Radial on his 18" chrome Bullits and says he likes them too. The G-Force DR is more for imports or is aimed that way but still work fine for any car.
Old Mar 17, 2004 | 01:47 AM
JKDZ28's Avatar
Yes you are correct i should have been more specific
they do say Comp T/A drag radial
im just saying from my own experiance, they are GREAT tires
wear fast tho
HectorM52
Jul 30, 2017 11:46 AM
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
dpw21562
Jan 23, 2015 04:58 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
