Valve spring & rocker suggestions?
I have a completely stock LT1 and my valve springs are going bad and I was wondering what are a good set of valve springs & rocker arms to go with? I might upgrade the cam in the future but not at this time, so I would want valve springs that are good enough so when & if I decide to change the cam they will be good enough. Thanks for the input.
Re: Valve spring & rocker suggestions?
Well, if you're sticking with a hotcam, then use hotcam springs. If you go with a cam any bigger than that, get some different springs. I wouldn't use hotcam springs for anything other than a hotcam.
oldschool
Feb 9, 2016 09:21 PM
