Resistor for abs light?
Old Mar 17, 2004 | 03:41 PM
97WRAITH's Avatar
I would like know if anyone has figured out a resistor value to get the abs light to come off or even if this will work.It is the plug on the rear end.I installed my 9" Moser and would like to do this without taking the bulb out.Thanks!
Rob.
Old Mar 21, 2004 | 08:47 AM
slopokrodrigez's Avatar
The BCM looks for pulses from the wheel sensors. More specifically, it looks for any DIFFERENCE between the wheel pulses. It is my opinion, and this is opinion only, that the resistor will only tie the signal high or low. But it will not pulse so this will not get rid of your light.
You could with a little circuit trickery, tie the rear signal to one of the front wheel signals and get rid of the light.
1996LT1Z28
Apr 14, 2015 07:15 PM
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
squarehead
Jan 15, 2015 07:02 PM
