Reusing Bolts...
Reusing Bolts...
I know this has been debated off and on, but I want to know if rod and main bolts can be reused during a rebuild. Are these bolts also TTY? It appears unanimous that the head bolts are TTY. The motor I am rebuilding had 120K on the clock (if mileage has anything to do with it). When rebuilt, it will be pushing 400hp at the flywheel.
I know many recommend replacing all high-stress bolts with ARP bolts. I understand this proactive approach, but is this entirely necessary? Has anyone out there reused main/rod bolts and experienced a failure? How difficult is it to press out the rod bolts, and how is this done without distorting the rod?
Thanks!
Thanks!
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
94DROPTOPZ28
02-05-2003 11:08 AM
