doing electric waterpump (pt#)
Old Mar 17, 2004 | 03:40 PM
simple's Avatar
do i need the GM gasket part # 10217886
and also in the same package as that seal it has what looks like an EGR gasket, kinda triangle shaped with 3 bolt holes and 2 bigger holes (odd shaped) in the center of it, is this an EGR gasket? i cant find the part number on that one since its in the same package as the above part#.......ideas?
thanks
Steve
Old Mar 17, 2004 | 04:02 PM
llafro's Avatar
You need the two gaskets that go against the block where the pump mates up to it. You take the cover off front of the stock pump, take all the innards out, plug the hole in the back, and bolt the pump onto the face. The CSI I used has an o-ring gasket that seals against the face of the pump.
Old Mar 17, 2004 | 09:00 PM
simple's Avatar
ok i'm assuming the 2 gaskets are the triangle shaped ones i mentioned?
but i dont need the round seal that is about an inch in diamter, i think it says on GM parts direct that it is the water pump drive seal.......
football4life
Oct 4, 2015 07:48 AM
plattted
Parts Wanted
Sep 13, 2015 07:17 AM
Daluchman1974
Sep 11, 2015 06:12 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
tdigger9899
Sep 7, 2015 10:56 AM
