E Brake
Old Mar 15, 2004 | 10:39 PM
eagleknight97's Avatar
E Brake
How can you make a very loose e brake, tight? My car is an automatic, but I would like to use my e brake sometimes, however, whenever i pull up on it, not much really happens. It slows very gradually, even when im totally yankin on it. Whats the deal.
Old Mar 15, 2004 | 10:52 PM
eddyj's Avatar
Wish I could help but I got my own e-brake problems after installing my ripper shifter a few years ago.
I removed a rigid wire with a rectangular loop on one end from, ahem, somewhere in the e-brake handle and can't figure where to put it back in. I thought I needed to do that to get the handle up far enough to get the console over it but looking back that may not have been necessary.
If you do the same thing I guarantee at least the pull on your handle will be tight because this wire seems to be designed to actuate (mechanically) the lever that catches on the lower sprocket of the e-brake handle. I am being somewhat sarcastic since you can't pull up on the e-brake handle at all without that wire being installed correctly.
Maybe this will trigger something to help you?
Old Mar 16, 2004 | 12:07 AM
Jeffs94Z28's Avatar
perhaps you could replace the spring with a new one? sounds like a problem my friend has in his 98 vette. after lending it to an $%# who did numerous ebrake slides.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
