Is 6500 Rev Limiter Safe?
Old Mar 16, 2004 | 11:44 PM
BlueCamaroZ28's Avatar
My PCM is tuned with rev limiter set at 6500 RPM. I have removed my Accel 300+ that has adjustable rev limiter.
The 355 LT1 engine went into my 1993 Jeep Wrangler YJ without the Accel 300+. When sand driving, hill challenge, it will go to rev limiter almost each time I climb a big hill.
Will the 6500 RPM be safe on the engine or should I install the Accell 300+ and set it at 6250RPM or maybe 6000 RPM.
I know it's not a Jeep Forum but I am in for the LT1 stuff, so, easy on me.
Old Mar 17, 2004 | 12:48 AM
95_LT1_6SPD's Avatar
you should be fine at 6500.
Old Mar 17, 2004 | 02:17 AM
RE AND CHERYL's Avatar
Cool
If it has stock springs, I wouldn't spin it that high.
my 2 cents
Old Mar 17, 2004 | 05:19 AM
my 2 cents
It has TPiS ported LT1 heads part# 500-511 with springs good for 0.600 of lift. Also, I have the following in the build of the engine:
Trickflow conrods pt no TFS-36570500
Speed Pro pistons pt no TRW-L2417F30
Rings pt no SLP-E-251K030
High volume oil pump MEL-M55HV
Cyl head bolts ARP-134-3601
Main bearing bolts ARP-134-5001
But maybe I should check if there is any benefit from revving to 6500 RPM with the ZZ9 cam.
Should I worry about bottom end at 6500RPM.
G-BODYT56
Jan 14, 2022 11:14 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
rideordie
Sep 7, 2015 08:22 AM
