Fans/actr fuse 6
Old Mar 15, 2004 | 06:31 PM
SLeeper94Z's Avatar
Fans/actr fuse 6
This fuse is blowing in my car underneath the hood,I replace it and it blows 5 mins later , what does this control ? how do i fix my problem?
Old Mar 15, 2004 | 06:36 PM
HBHRacing's Avatar
it feeds the 02 sensors, skip shift and reverse lock out selinoids, all 3 fan relays.. thats all I come up with right now with the limited diagrams I ahve on me. I would start with maiking sure teh fan realays are good and not getting hot. see if it blows when the fans come on. they could be bad and pully too many amps
Old Mar 15, 2004 | 06:41 PM
SLeeper94Z's Avatar
Fuse 6
if skip shift is not operating how would it affect a A4 car?
what does the reverse lock out solenoid do?
My fans still run , do u know what could be blowing thsi fuse u think a wire was burned or something
Old Mar 15, 2004 | 06:47 PM
HBHRacing's Avatar
if your an auto don;t worry about skip shift... if it's not a dead short (blows as soon as you put the fuse in) then it's probaby not a wire. but it still could be..
fan motors can go bad and overheat pulling too much power and blow a fuse. the fan motor should be getting hot if this is the case but not always.
I would try unpluging the fans one at a time and see if it still blows
Old Mar 15, 2004 | 07:08 PM
I would put odds on a burned O2 wire that is shorting to ground.
Old Mar 15, 2004 | 07:12 PM
HBHRacing's Avatar
I would tend to agree if he said that after he installed it and drove the car it would blow. but I dunno weather it blows when he is just stitting there or not.. esp with headers that 02 harnes is so easily melted..
Does it blow at teh same time everytime or just at random times when you are acualy moving the car?
Old Mar 15, 2004 | 07:45 PM
SLeeper94Z's Avatar
everytime the car is started it blows and it makes a squealing noise for a sec
Old Mar 15, 2004 | 07:52 PM
HBHRacing's Avatar
it;s not teh fan squealing is it? unplg them and try it. if it still blows start looking at o2 sensor wires
Old Mar 15, 2004 | 09:26 PM
SLeeper94Z's Avatar
fuse 6 does not have anything to do with the Tranny does it ?
Old Mar 15, 2004 | 11:13 PM
Not for an automatic, according to the owner's manual:
6 - Coolant Fan Relays; EVAP
Canister Purge Solenoid; Exhaust
Gas Recirculation; Low Coolant
Relay; Reverse Lockout Solenoid
( 10 Amp.)
Old Mar 16, 2004 | 02:32 AM
SLeeper94Z's Avatar
maybe found my problem
ok, I think i found my problem once again my car starts off like in 3rd gear, Y does this do this?...... if i manually shift the car into first its a torque monster but i dont have a standard lol, Is this a solenoid? or could this be a fuse ?... i had no such problem before the tranny was rebuilt, any help thanks
Old Mar 16, 2004 | 01:07 PM
SLeeper94Z's Avatar
Anyone?
Old Mar 16, 2004 | 04:34 PM
SLeeper94Z's Avatar
Has anyone had this problem car is in 3rd gear when they take off ina Auto? everything will work when u downshift Manually.... what controls donwshifting?
Jeff1904
Jun 5, 2016 05:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28cam1993
Sep 9, 2015 04:08 AM
RUNMYTA
Jul 15, 2015 07:50 PM
