standard length pushrods with new cam?
Old Apr 22, 2007 | 11:34 PM
tnmotown's Avatar
right now i have comp cams lifters, pushrods, and 1.6RR that installed in my stock motor about 6,000 miles ago. Now the comp pushrods are stock length, my question is will the pushrods work if i switch them over to my 383 with a XFI 468 cam? Is there a different size i have to get or would they be able to work? I know i can keep my lifters and rockers, just not sure about the pushrods....
Old Apr 23, 2007 | 03:16 AM
1997blackz28's Avatar
you should measure to be sure of the proper length.
Old Apr 23, 2007 | 07:56 AM
If there has been no machine work to the block deck or head surface, you normally don't have to worry about pushrod length, but measuring leaves no doubt.
Old Apr 23, 2007 | 09:24 AM
tnmotown's Avatar
it hasnt been decked and i think the heads might have been milled to 54cc compared to our 56cc. Will that make a difference?
Old Apr 23, 2007 | 09:34 AM
CrazyLT1's Avatar
You may need to go just a bit shorter than I think. Maybe like 7.100-7.150" instead of the stock legnth of 7.200"
Old Apr 23, 2007 | 11:00 AM
Measure.
Old Apr 23, 2007 | 11:02 AM
89TramsAmGTA's Avatar
Measure.
Old Apr 23, 2007 | 11:33 AM
tnmotown's Avatar
ok i will measure it just to be safe. thanks
HectorM52
Jul 30, 2017 11:46 AM
chuyz28
Feb 19, 2015 12:50 AM
alex5366
Feb 17, 2015 08:12 PM
Roadie
Feb 16, 2015 10:34 AM
Jason Short
Jan 19, 2015 06:34 PM
